Firma de BIOS
Instruction to create a bootable USB-Stick
  • Copy the folder usbdos to your hard disk.
  • Start the HP USB Disk Storage Format Tool.
  • Select your USB-Stick under Device
  • Choose FAT-32 under File system and activate the check mark Create a DOS startup disk.
  • Insert the path to your usbdos folder under using DOS system files located at:.
  • Press the Start button and wait until the tool has formatted the USB-Stick and has copied the 3 system files.
  • Rename the filename of your flashtool and the BIOS file, if they have more than 8 characters (not the file extension!).
  • Copy your flashtool and the BIOS file onto the USB-Stick.
The DOS system files are normally invisible, because their file attribute is set to hidden. If you would like to show these hidden files, you have to enable the option: "Windows-Explorer / Tools / Folder options / View / Show hidden files and folders" and to disable the option "Hide protected operating system files".
