Instruction to create a bootable USB-Stick
The DOS system files are normally invisible, because their file attribute is set to hidden. If you would like to show these hidden files, you have to enable the option: "Windows-Explorer / Tools / Folder options / View / Show hidden files and folders" and to disable the option "Hide protected operating system files".
- Copy the folder usbdos to your hard disk.
- Start the HP USB Disk Storage Format Tool.
- Select your USB-Stick under Device
- Choose FAT-32 under File system and activate the check mark Create a DOS startup disk.
- Insert the path to your usbdos folder under using DOS system files located at:.
- Press the Start button and wait until the tool has formatted the USB-Stick and has copied the 3 system files.
- Rename the filename of your flashtool and the BIOS file, if they have more than 8 characters (not the file extension!).
- Copy your flashtool and the BIOS file onto the USB-Stick.
- 150.7 KB
- 12
- 36.7 KB
- 13
