MacBook Pro 13" Touch Bar A1989 logic board does not turn on anymore
swaake
Hello!
I do have two MacBook Pro 13" Touch Bar A1989 logic boards.
1) does not turn on when mounted in the housing
2) does work fine
Having board 1 only powered by USB C the USB-C Voltage does not get higher than 5V and there are 0.2W delivered from the USB-Power-Adapter. If I do the same with board 2 the voltage get's at 20V and takes 7 to 9.5W
How can I find the reason for board 1 not taking more power?
Repair Tv & Laptop
Hello!
2) does work fine
Having board 1 only powered by USB C the USB-C Voltage does not get higher than 5V. If I do the same with board 2 the voltage get's at 20V
C7032 PIN 1 PPDCIN_G3H ! HOW much voltage you get there and check if there's a short circuit .
Repair Tv & Laptop
12VDC with 0V on C7032 P1 and 12V on C7032 P2 ?
I told you to check if the ic (CD3215A) goes with a highly temperature when it get injected by 12v if not a suggest to change your ic of charge U7000 .
swaake
No temperature rise at UB300...
is there any possibility to power it externally and have just the data transferred?
swaake
Both the same:
FB201: P1: 0V, P2: 0V, P1-P2: 0.42Ohm
swaake
is the charge function required ? can't it be skipped by applying power directly at the input of the superior circuit?
