- Joined
- Jan 13, 2018
- Messages
- 1,843
- Thread Author
- #1
Dell Laptop Manufacturing Mode Active :
This problem occurs because the Service Tag is not programmed in the BIOS, or we can say that the BIOS is not able to update the service tag.
Access the BIOS:
Turn off your computer.
Turn it back on and press the appropriate key to access the BIOS setup utility. This key is often F2 or Del but may vary depending on your Dell model. You’ll usually see a message on the screen during the boot process indicating which key to press.
Navigate to System Information:
Once in the BIOS, navigate to the “System Information” or “Maintenance” a similar menu option. The exact name may vary depending on your BIOS version.
Change Service Tag:
In the “System Information” or “Maintenance” menu, you should see an option to change the service tag. Select it.
Enter New Service Tag:
Enter the new service tag and save your changes.
Exit and Save:
Save your changes and exit the BIOS.
Setup Above Not Work :
Clean Me Region is necessary or build a new Bios must be done see our resource .
Access the BIOS:
Change Service Tag:
Exit and Save:
