- 16 MB
- 3
Old bios has the same result!!!Dear Team,
I downloaded and flashed the Bios with the Version presented above. Aftern flashing, everything works fine besides my Graphic card and HDMI port. The GPU is not recognized by the PC, as if it would not exist at all. I tried some windows related workarounds but no success.
HDMI Port does not work as well, I tried multiple plugin variants with monitor, tv and also multiple adapters, and no result.
I have a MSI GS65 Laptop with GTX1070 GPU.
Is there any solution you could point to, maybe another BIOS Version?
Kr,
Stefan.
Also, the Bios interface is not the same anymore, it used to be MSI Click Bios, and not it s just the standard one.hi Admin,
I guess you asked my if my old BIOS had same issues?
My answer: the old bios crashed during an attempt to update and since then I was not able to use the laptop anymore, i had no image and such, it just did not start anymore.
Once I flashed the bios with this version from here, everything works again except for the 2 issues the GPU and the HDMI Port.
Thanks in advance.
If the Gpu doesn't work how do you get a displayed screen.Also, the Bios interface is not the same anymore, it used to be MSI Click Bios, and not it s just the standard one.
I have 2 graphic cards, one from Intel and one from GTX INVIDIA. PC runs now only on intel.If the Gpu doesn't work how do you get a displayed screen.
Use another gpu graphic.I have 2 graphic cards, one from Intel and one from GTX INVIDIA. PC runs now only on intel.
I do not see what you mean by another GPU: the GTX Invidia 1070 is integrated on the mainboard of my Laptop, and it is not being recognized. I would send you some pictures, maybe it s clearer like this but I do not see any option here to attach files?Use another gpu graphic.
that is not an option, how should I use another GPU, I do not understand your point, can you please explain? You can see clearly on the Mainboard in this thread that you can not just switch to another GPU as it s integrated on the mainboard.I do not see what you mean by another GPU: the GTX Invidia 1070 is integrated on the mainboard of my Laptop, and it is not being recognized. I would send you some pictures, maybe it s clearer like this but I do not see any option here to attach files?
My question was if there is another type of BIOS for this mainboard as the issue is not related to functionality of GPU but to the BIOS Version. Thanksthat is not an option, how should I use another GPU, I do not understand your point, can you please explain? You can see clearly on the Mainboard in this thread that you can not just switch to another GPU as it s integrated on the mainboard.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
