VIVAX 24LE78T2S2 Dump TE.MS3663S.EA67
admin
Dec 2, 2017
34,593
VIVAX 24LE78T2S2 TE.MS3663S.EA67 Dump
Panel : M236HJJ-P02
Hello sir, i want to buy tv firmware. my tv is 24'' startimes.
te.ms3663s.ea67
25q64
it looks same with your firmware for VIVAX 24LE78T2S2 TE.MS3663S.EA67. can i use this firmware.
this dump need to be writed with a programmer tool like rt809 .
Is there any bin converter so that i can use USB flash.
my tv has burning mode i failed to remove it with buttons and tv cant turn off. if you can help me with hard reset by short circuiting hack for 25Q64FVSIQ i can pay.
You can try to entre mode service :
Press Input Key, press the numeral key 2580
TV is just showing colors like this. it is not responding to remote or buttons. help me with hard reset 25Q64FVSIQ or USB firmware.
have try to power off then power on your tv with tv key button .
it doesn't turn on or off either with remote or buttons. tried several times. and it comes just when i connect power on its on.
You need a programmer tool like rt809 if you would like to resolve this problem .
try to press the TV menu button several times, on some Chinese TVs it gives results
