All what we have for now is a Schematics file but we will check for a boardview if it's availablehello anyone have an a2378 820-02415 pcd boardview ?
thanks you
Try to use another screen.the device boot normaly and i see image of the lockscreen
and touch work
PPVCC_MAIN_LCD_SW_CONN = 4v(only when display on)
PPVCC_MAIN_LCD_SW = 3.9v ( only when display on )
GPIO_PMU_TO_LCD_PWREN_1V2 = 1,25v ( only when display on )
PP_LUME_OUT = 0v (always)
PP_LUME_OUT diode mode value 0,580v
PP_LUME_OUT should have 12V or more than that , check if there any short circuit.already tested with another new screen same problems
No boardview available for now .Still no boardview?
I have same iPad which is dead. Current draw is 0,5A@5V when battery is connected and 0,1A without battery. Didn't found a short, I can measure 3,7V and 5V around the PMIC. With thermal cam the PMIC gets slightly hot about 30°C with battery connected. Checked a lot of caps, no short. What do you think is it worth to change the PMIC or other ideas? Thanks
We use essential cookies to make this site work, and optional cookies to enhance your experience.
