Acer Acer Predator PO3-640
naighba
MotherBoard Part Number
Acer Predator Orion 3000 PO3-640 B66H6-AD2 V: 1.2
Laptop Serial No
DGE2WEF027216040069600
Hello. I ran into an issue with the BIOS update for a desktop pc Acer Predator PO3-640 and the bios got bricked.
I will attach what I have extracted from the BIOS that is not working.
I used files that I found here https://www.repairlap.com/threads/acer-predator-orion-3000-po3-640-b66h6-ad2-v-1-2-bios.22660/ for this motherboard and got the pc to start but the DMI is all blank and for a different model.
I would need the a original dump so I can compare files and modify the coresponding serials if possible or if someone can do this for the file present here I would be grateful.
I need the model and serial in the DMI for waranty reasons. Thank you !
naighba
Thank you for the quick reply !
I will test it tomorrow as I cannot download the file as my download limit was reached for today
Hello. I tried with the ROM and the PC does not start. This motherboard has 2 Chips one with 4mb and one with 16mb. Is it possible that I need both ?
I works well with the files you provided here : https://www.repairlap.com/threads/acer-predator-orion-3000-po3-640-b66h6-ad2-v-1-2-bios.22660/
Motherboard is a B66H6-AD2 V: 1.2
Thanks
Use this link all instructions are available on how to edit information of your bios.
naighba
Thank you for the reply but I already tried with DMI Utility, windows and DOS version and none can edit
it should work Try and reply ,use them both .
naighba
Tried both files and it still does not work ... Reverted to the 16mb file in the original post and the motherboard starts as expected.
naighba
Could you please send me the original B66H6-AD2 V: 1.2 16mb file ? I will compare and edit the tag and serial manually with Hex Workshop. Thank you
