Convert Dis to Uma
admin
Dec 2, 2017
34,520
DIS-UMA Convert
Hp 431 Without graphic
We can convert hp 431 Ati
Graphics to intel graphics.
By just removing gfx coil.
Display automatically switch to intel.
No need to remove ati chip and other components
Do this and enjoy
UMA
THOSE THE LAPTOP MODELS WHICH ARE CONVERTING TO THE NON GRAPHIC AFTER REMOVING THE GRAPHIC SUPPLY
DELL INSPIRON 4110
HP PROBOOK P4540
HP 15-R022TX
LENOVO G570
HP NOTEBOOK R53
DELL INSPIRON 5520
ACER LA-7912P
DELL 3521
DELL 3537
DELL 3421
SONY MBX 237
HP G6 R33
LENOVO T420
LENOVO Y560
LENOVO G570
HP PAVILLION DV6/DV7
BOARD PART-----
PCB HPMH-41-AB6200-D00G
PWA: HPMH-40GAB 00-D
TO CREAT INTEL BOARD
JUT REMOVE GFX COIL
PUT JUMPER IN M50 TRANSITOR IN LEG 2 TO LEG 3
THEN JUST SHIFT RJ8 RESISTOR PLACE 10K AS SHOEN IN PICTURE
THEN WORK WILL DONE
HP 15 R series LA-A992p Dis to Uma
Just remove PLV3 and PLV2.
dell inspiron n4050 dis to uma
Just remove coil PL9201 & PU9303. No need to remove ati chip.
PU9303 is just below fan connector(back side of pcb)
PL9201 is near Lan Chip.
100% working .
lenovo G500s dis to uma
G500s dis to uma
PL803 - remove
Dell 5520 LA-8241P Dis to Uma
Only remove gfx coil PL800 and done
Lenovo G770 LA-6758P
move a resistor R702 to the position of R707 , and a resistor R703 to the position of R705.
HP-15 R62 DIS TO UMA
PCB-DA0R62MB6E1 REV:E
Just remove 2 coil PL20 nd PL23 100%
mbx-276 without
jUST REMOVE THE GFX COIL
DELL INSPIRON 4110
TO MAKE NON-GRAPHIC JUST REMOVE THE GRAPHIC SUPPLY COIL
IT WILL WORK
CONVERT TO UMA BY REMOVING GFX SUPPLY
THE LIST OF THOSE MODELS WHICH WE CAN EASLLY CONVERT TO THE UMA AFTER REMOVING THE GRAPHICS SUPPLY COIL ....
LENOVO G500S
HP 431
DELL 5520
SONY MBX-239
LENOVO G580
HP NOTEBOOK R53
DELL 3521
DELL 411O
HP PROBOOK P4540
LENOVO T420,Y560,G570,Z570
HP DM4-3000
LENOVO U460
LENOVO IDEAPAD S510P
MODEL LENOVO IDEAPAD S510P TOUCH 20299
Mainboard MODEL LS41P MB 12293-1 48.4L106.011
REMOVE PL8201 AND PL8202 ONLY
HP G6 Quanta R23 with discrete on UMA
Quanta R23
Move the R836 in position R837
Remove R123 R121 + pc100 close or you can simply delete PL22
Move R369 to position R368
Samsung T09-305V5A
To disable the discrete graphics, enough to remove one resistor, R831
SONY MBX-239 NON GRAPHICS CONVERSION Topic is solved
TO CONVERT SONY MBX-239 Mainboard JUST REMOVE GRAPHICS VOLT COIL ONLY ITS DUAL SUPPORTED Mainboard .
Dv7-6c54er is it possible to convert uma
amd or intel in both cases this mb comes with dual graphic card just remove graphic chip supply its works
Dell Inspiron 14R N4050
REMOVE GFX SUPPLY
HP pavilion G6 UMA conversion
The most simplest conversion.
DA0R33MB6D0 REV D (R33)
Remove PL27
Remove R550 and place @ R549
That's it
UMA
DELL INSPIRON 4110
HP PROBOOK P4540
HP 15-R022TX
LENOVO G570
HP NOTEBOOK R53
DELL INSPIRON 5520
ACER LA-7912P
DELL 3521
DELL 3537
DELL 3421
SONY MBX 237
HP G6 R33
LENOVO T420
LENOVO Y560
LENOVO G570
g580 conversation dis to uma
G580 MB no lg4858 only pl9201 qoil open and nvidia IC open display come good job
DELL INSPIRON 5520 CONVERT TO UMA
TO CONVERT TO UMA JUST REMOVE THE GFX SUPPLY COIL
Do this and enjoy
HP Pavilion 17-e033er (Quanta r75) alteration of Discrete in the UMA Topic is solved
IF ANY ONE HAVING THIS TYPE Mainboard.PLEASE TRY FOLLOWING METHOD TO CONVERT DIS TO UMA. I AM NOT HAVING THIS BOARD.I GOT IT FROM ONLINE.
Remaking a UMA simple move one strap: Remove R489 (10k)> put R501 (10k)
located next to the FCH
Acer three models Graphic To non Grapchics convert Topic is solved
Below listed Acer laptop Mainboard can be converted to Graphics to non Graphics
to do so we just need to remove Graphics ic's Coile only
but to reduce power consumption remove graphic ic's power supply components it is not necessary to remove them if you don't bother about power consumption
you can use this Convert Graphic To non Graphics techniques of removing Graphic ic's supply coile
in every laptop which has switchable Graphics feature
Switchable Graphics means when you go in to windows and you can see two graphic drivers running at the same time in device manager > Display adapter tab
LA-7912p
LA-6901P
LA-9535P
