Dell Alienware 15 LA-C912P REV2.0 No Power
RiTCH50
Hi folks hope somebody can help!
Dell Alienware 15 LA-C912P REV2.0 laptop here that I have No history of. Don't know what previous has happened just dead no power at all.
The only thing I can find is what looks to be a burnt resistor? I cannot see the value, have attached the pic.
The laptop does not power at all, nothing. There is 19V at 1 side of the resistor, 0.89 at the other.
Any pointers would be amazing please!
Thank you and good health, Rick
RiTCH50
Just thinking out loud here but the data sheet states:
VCC 28 Input supply from adapter or battery. Use 10-Ω resistor and 1-µF capacitor to ground as a low pass filter to limit inrush current. A diode OR is connected to VCC. It powers charger IC from input adapter and battery.
I can't find a schematic for the mainboard and so would it be fair to assume that the required replacement resistor should be 10-Ω going of the TA datasheet??
Thank you and please forgive my ignorance!
Rick
-Pin 28 vcc MUST GET 19V When you are in use for the AC adapter :
check impedance between vcc pin28 and the ground how much you get.
-PQ702 check impedance between pin 5 and the ground .
RiTCH50
Thank you!
With no power to board I get 6.86k on pin 28 to ground
pq702...i'm not sure, counted up like charging a cap then went off?
Again both with no power to board
RiTCH50
Thank you Admin -
I get 95.4 reading between pin 5 and ground when multimeter set to 200K.
(again no power to board)
Thanks,
Rick
RiTCH50
Hi Admin.
I replaced PR707 - it was burnt and now get 19V good.
Checked pin 3 of PD700, 19v good.
Board still refuses to power :-(
Thank you, Rick
RiTCH50
So... I just checked pin pin 6 acdet 2.57v on the chip side, 19.36v at the "other" side of the resistor PR716, This reads 247k - I beleve from much much googling that the value should be 324k?
Or I may be barking up the wrong tree!
Thank you Admin :)
