- Joined
- Dec 2, 2017
- Messages
- 34,438
- Thread Author
- #1
Symptom: The TV takes longer to power on than normal.
The TV takes longer to power on than normal. You may hear several clicks
while the TV attempts to power on.
Cause: The electrolytic in the capacitors on the power supply board over time
will dry out causing the power supply to shut down during its initial power on
cycle.
Repair/Solution:
Refer to the capacitor cross reference guide below for the list of the capacitors
that should be replaced
cycle.
Repair/Solution:
